Noise at turn off
0 Members and 1 Guest are viewing this topic. Read 3423 times.
HooStat
Noise at turn off
« on: 3 Nov 2010, 05:40 am »
Should a Bryston amp (especially a new one) make any noise when the power is turned off via the front switch?  A small pop?  Or should it be dead silent (with normal speakers at 88 db sensitivity)?
danman
Re: Noise at turn off
« Reply #1 on: 3 Nov 2010, 01:01 pm »
I have a 4BSST2 and I always get a small "pop" on start up and shut down. I hope it is normal as well!!! :o
95Dyna
« Reply #2 on: 3 Nov 2010, 01:18 pm »
Small pop on my 7B SST2's.  It's perfectly normal and independent of speaker specs.
Anonamemouse
  • +52° 03' 30", +4° 32' 45"
« Reply #3 on: 3 Nov 2010, 03:15 pm »
When I turn it off I hear something like a static click, left channel first, right channel right after.
werd
« Reply #4 on: 3 Nov 2010, 03:21 pm »
last on first off with amps. You shouldnt get any noise with that procedure. Don't turn your preamp off first.
etcarroll
« Reply #5 on: 3 Nov 2010, 03:21 pm »
30 year old 4B that pops on shutdown, I believe James once said its the caps discharging, but I could be wrong.
larevoj
« Reply #6 on: 3 Nov 2010, 03:37 pm »
I have the 4BSST2 and it does the exact same thing.
AVnerdguy
« Reply #7 on: 3 Nov 2010, 05:21 pm »
Most likely the PS caps discharging. Amps with hefty power supplies that don't use relays on the speaker outputs need to discharge the large capacitors through a bleeder resistor and the load/speakers (so the tech doesn't get blasted when he opens the unit for service). Harmless if it's a soft thump, hiss, pop or however you want to describe it. Louder on efficient speakers and barely noticeable on less efficient speakers.
