LC Audio ZapFilter Mk II
0 Members and 1 Guest are viewing this topic. Read 7034 times.
chino
« on: 7 Mar 2004, 11:32 am »
Hi !
Anybody here has this mod done to theirs? It is worth it? Reviews anyone?Forgive me I dont know where I should post this topic but as it concerns 2ch mod and Im interested in getting one. My philips963sa serves as double duty [cdp for my 2ch audio & HT]
mgalusha
« Reply #1 on: 7 Mar 2004, 01:04 pm »
Chino,
I have one of the LC ZapFilter Mk II output stages and have used it in both a Marantz CD-67SE and a Philips SACD 1000. It was much nicer than the original output stage of the Marantz. It lived in the Marantz for a while until I bought the Philips. I had the Philips modded by Stan Warren and while it was quite a bit nicer than stock I was somewhat disappointed with the sound.
I installed the ZapFilter in the Philips and was much happier with the overall sound. Very clean and clear without being harsh. The bass was full and articulate. Not as deep as I've heard but quite good and satisfying. Imaging was excellent with a good deliniation of the instruments and an excellent presentation of depth.
I'll put it this way, I would still be listening to it had my SACD 1000 not died.  I felt no need to replace it and it sounded very good. I may take a stab a repairing the Philips one of these days but I had the opportunity to pick up the Parts Connexion modded Denon 2900 and I like the sound better than the modded Philips so my need for repairing the Philips is not pressing. :)
I am fairly certian the ZapFilter would better the existing output stage of your 963. One thing to keep in mind is you have to find room to mount the power supply in addtion to the Zapfilter. This amounts to a small toroid transformer about 2 1/2 inches in diameter and a PC board about 1 x 3 inches in size. If the 963 is similar to the SACD 1000 this means you will have to remove 4 surface mount resistors and solder the input wires to the pc traces where the resistors were. This can be challenging as they are not very big.
Hope this helps,
Mike G.
chino
« Reply #2 on: 8 Mar 2004, 01:09 am »
Thanks for the info and review mgalusha appreciate it. The only mod Ive done to the philips was the BG powercap. That was easy. I might try the zapfilter next. Thanks for the tip. Oh Ive got this off a site but everythings in chinese. I wonder if it works the same thing as the zapfilter... interesting.
mgalusha
« Reply #3 on: 8 Mar 2004, 04:48 am »
Chino,
I think you're correct, it does appear to be an output stage using miniature tubes. I found a page with info about it but it's in Chineese. I ran it through bablefish and it makes a little more sense but not much. :)
http://www.audioxtension.com/rev/tubefilter/tubefilter.htm
