0 Members and 1 Guest are viewing this topic. Read 20684 times.
Is there a chart somewhere for the resistor values?
DaveyW, do you have a link to a plan for the varable load box, or is something you cooked up? Is it something as simple as a pot on one leg, with in/out jacks? If so what value range?thanks.
Is there a chart somewhere for the resistor values? I assume it inserts on one leg of the connector, sort of like a light switch....correct?DaveyW, do you have a link to a plan for the varable load box, or is something you cooked up? Is it something as simple as a pot on one leg, with in/out jacks? If so what value range?thanks.
