0 Members and 1 Guest are viewing this topic. Read 9026 times.
Just a thought/question. Given the average noise levels in a living room (i.e. http://www.consultnet.ie/occupational%20noise.htm) are we really going to hear all that difference or perhaps a fraction of it? I'm not talking about an isolated chamber but a real world room. I've seen people for example post about hi-rez in a car and wonder why given the limitations of the environment.
Many, many people are quite happy listening to vinyl LP records or magnetic analog tape both of which have a much, much higher noise floor.
My initial reaction also. A decent phono preamp has a s/n of 85db and many will swear by it's superiority over any digital source no matter the 20db difference in favor of the digital.
This isn't a problem. If you look at the recovered waveform of a 24 bit -90dB signal played back on the best of todays dacs most of them will barely do 20bit replay as far the noise floor is concerned. That negative 24bit 90dB waveform is not reproduced perfectly either,it has some distortion presentwhich you can see when you look at it. I am not sure that a 24 bit recording has better than 85dB of actual usable dynamic range. I define usable dynamic range as having lower than 3%THD at the lowest recorded signal level. More to the point your room's ambient noise floor is lucky to be 45dB. If you add 85dB to that you have a 130db peak SPL which is louder on peaks than even I want to listen at. The prevalence of compression in todays recordings assures that we won't even need the 85dB of dynamic range that 24bit might have.Scotty
werd,go read one the DAC reviews on the Stereophile website and check out the graphs in the measurement section showing the true noise floor of 24bit dacs as well as what the -90 waveform looks like and you will see that the -120 dB noise floor isn't usable.Scotty
With the big movement in hi rez recording/down loads, when is solid State amplification going to catch up?. We see 192/24 recordings more available but we also see amplifiers at 110 db noise (and these are expensive amps). Here its only 18 bit resolution at best. Will we ever see 144db (24bit) noise floor out of a solid state amp?
Of course we don't Turkey.
Do we _need_ to see 144 dB S/N in an amp? Typical recordings and listening rooms don't even take full advantage of Redbook in terms of dynamic range and S/N.
This has nothing to do with redbook, look at my op
