Norh SE-9 and Axiom M3ti speakers ?
0 Members and 1 Guest are viewing this topic. Read 1870 times.
laumans
« on: 6 Mar 2004, 11:13 pm »
Hi,
Has anyone experience as to how well the Norh SE-9 and the Axiom M3ti speakers work together? The Axiom M3ti have about 89 db efficiency and I wonder whether this is enough for the Norh SE-9. To be precise, I would be using this setup in my mid-size living room.
Thanks for your input,
M
PS: As you can imagine, aiming at the above setup, I'm trying to go low-budget. Any suggestion for a good, low-budget speaker stand? I know this doesn't belong here..but while you are at replying, anyway...
Woodsea
« Reply #1 on: 6 Mar 2004, 11:37 pm »
Do you have the axioms now?
The tubes will dampen the shrillness of the axioms.  But for the same price Ascendacoustics CBM 170 will do much better.  Just my opinion though.
Good luck in your original endevour though.
-Eric
laumans
No, not yet
« Reply #2 on: 6 Mar 2004, 11:48 pm »
Quote from: Woodsea
-Eric
No, I don't have them yet but am considering buying them.
