0 Members and 1 Guest are viewing this topic. Read 15359 times.
Check out the Usher Audio 520.....Link...A few reviews....here......and ....here...
Where do you see cone break up at 4k, Anand? It's not obvious to me.Are you speaking of the step down at 1.5k? It's marked on the decay plot as significant, too.
The designer definitely dealt with the issue, and it's likely not to be audible as it is ~15 dB down on axis, and most likely even more off axis. But like all smaller loudspeakers when you start kicking this fella up above 100dB, then that little woofer has a hard time keeping up.
Distortion is audible down to -30 below reference, sometimes a little further.
I had a pair of the Usher S-520 in the bright yellow finish. Absolutely gorgeous speakers but I did not get into their sound.Also owned both of the Quads mentioned. I much preferred the 12L over the 11L.But the monitor I like best in your price range is the Polk Audio LSi7. It had the most natural presentation in my system. This is all very subjective so you'll be taking a chance if you don't audition the speakers in your system.
