Congratulations BIG B, Constant Directivity Wave Guide Patent to ISSUE 11/16
0 Members and 1 Guest are viewing this topic. Read 2980 times.
John Casler
Many years ago, after Brian had adopted his Planar Ribbon path, he evaluated the qualities of Planar and Ribbon Drivers and looked at further means to improve upon their performance.
While it is clear that a good Planar Ribbon can do a lot of things, it is also clear that dispersion and directivity was not their strong suit.
Over 5 years ago, Brian decided to implement a technology of combining his Planar Ribbons with an acoustic lens/aperture/wave guide that would cause the sound to behave and respond to moving through the opening in a way that produces a greater and constant directivity to the frequencies he chose base on the specific size of the opening.
Upon using this Wave Guide he then applied for a US Patent.
Just recently he has been informed that the Patent 7,835,537 will issue November 16, 2010.
I have a little experience with patents and have had a few issued myself.  Let me tell you it IS NOT an easy process.  The original submission is almost 100% of the time rejected, and you need to argue and clarify CLAIMS for YEARS.
In this case it took 5 years.
Speaker and Audio technologies are often very technical and address the Physics of Sound Propagation, Transmission and other elements, so just writing the claims and how they are novel can also be a challenge.
While many may not know this Brian is a member  of the AES. (Audio Engineering Society) and pays very strict attention to the Sciences of Audio and Psychocoustics.
I remember hearing about this idea of his and how it would affect the sound waves as they passed through the Acoustic Lens many years ago.
I just wanted to take this opportunity to CONGRATULATE Brian on developing this technology to the point it could be patented and then tenaciously pursuing it through the gauntlet laid down by the patent examiners.
We will be issuing a Press Release to the Audio Media, but I wanted to post a quick congratulatory post.
CONGRATULATIONS B!!
« Last Edit: 28 Oct 2010, 09:45 pm by John Casler »
srb
Over 5 years ago, Brian decided to implement a technology of combining his Planar Ribbons with an acoustic lens/apature/wave guide ...
... We will be issuing a Press Release to the Audio Media, but I wanted to post a quick congratulatory post.
Congratulations.  When you do issue the press release be sure to use the word aperture.
John Casler
Hi Steve,
Typo corrected, thanks for pointing it out.
Brian Cheney
    • http://www.vmpsaudio.com
Given the triviality of some loudspeaker patents, I must admit this one is based on a known principle--the diffraction slot.
To make this work with planars took some doing, and since filing, I have made a few refinements to the basic idea.  Well executed, the waveguide gives constant directivity with frequency over a 180 degree angle (plus/minus 90 degrees).  The drawback is that the same amount of treble energy is distributed over a wider angle, resulting in an HF rolloff.  However, this is easily corrected nowadays with our digital controller, though a new version of the waveguide ameliorates the rolloff almost completely without EQ.
Constant directivity is a necessary step to delivering flat amplitude response to the ear, which is necessary for true high fidelity performance.
I should mention there were many objections filed by opponents to this patent app, and it was rewritten several times until the examiner was pleased to issue it.
John Casler
For those who are not familiar with VMPS and the CDWG (Constant Directivity Wave Guide) here are a couple pictures of models with the CDWG
Above are the RM v60 and the RM30.
Notice the vertical slot running in the front of the speaker.  THAT is the diffraction slot B talked about.
As the Sound Pressure Waves are forced to travel through the controlled guidance of the slot, they encounter the guides walls that keep them from dispersing as sound waves normally do.
Once they exit the slot, this resistance of the wave guide is gone and they respond by dispersing immediately to a very wide angle.
A simple illustration of this would be the nozzle on a garden hose when it is set to "SPRAY".  The water after leaving the nozzle disperses evenly in all directions (directivity)
Darac
