Multiple sub-woofers
0 Members and 1 Guest are viewing this topic. Read 3082 times.
ttan98
« on: 27 Oct 2010, 12:07 am »
I understand there are a few technical papers written about the merits of using multiple subs e.g. Gedlee, et. al. I like to find a paper or papers where it explain how the subs are connected up
including:
1. No of amps used, how they are connected, in phase or out of phase.
2. Placement of subs.
3. No of subs, 3 or 4 (you take on this)
4. any other info which will help me to set them up
5. Types of sub that can be used, sealed, vented or ripole, etc
Please direct to one or multiple papers where I can find the above info. After that I will NOT be asking you to assist me.
ttan98
Re: Multiple sub-woofers
« Reply #1 on: 27 Oct 2010, 12:17 am »
I would appreciated if you can direct me to the right documents. Thanks for your time.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #3 on: 27 Oct 2010, 02:02 am »
brj and ttan98, you have pm's.
Anand.
ttan98
« Reply #4 on: 27 Oct 2010, 01:50 pm »
Anand.
Hi
I have changed my email address, the new address you get it from my profile.
poseidonsvoice
« Reply #5 on: 27 Oct 2010, 01:56 pm »
Hi
Check your 'MY Messages' link on the top of your screen. You should have received a message from me last night.
Anand.
