Question for Torus owners
0 Members and 1 Guest are viewing this topic. Read 1714 times.
jaxwired
« on: 25 Oct 2010, 06:06 pm »
Hi guys.  I've got a Bryston 4bsst2 and BP6 preamp.  I am intrested in the new Bryston BIT power conditioners that will be rebadged torus units.  I have a decent conditioner now which I plug everything into except my amp which runs to the wall directly.  I don't want a power conditioner to limit current to the amp.
Do you guys plug these big bryston amps into the torus?  No problem?  Good results?  Any thoughs are appreciated...  :)
VOLKS
Re: Question for Torus owners
« Reply #1 on: 25 Oct 2010, 07:05 pm »
I plug my 4BSST2 into  my Torus......i like to crank it sometimes.....never had an issue with current limiting yet.
Phil A
« Reply #2 on: 25 Oct 2010, 07:16 pm »
Yes - I have the 20amp Torus and I plug my 14BSST into it.  The first time I seriously listened to the Torus in the store a friend who hates plugging amps into power conditioners demoed the unit with amps plugged and unplugged and it was really noticed when it was not plugged in.
werd
« Reply #3 on: 25 Oct 2010, 07:49 pm »
Hi
The Torus conditioners are really not cheap to buy. So you might consider selling the 4Bsq and buying a new 14B instead of a keeping the 4B and buying a Torus conditioner. The new  14B have the transformers used in the Torus that gives it more jam. It is also choke filtered unlike the 4B so its a cleaner amp. If you have a conditioner already, use it for your front end and pre, plug your 14b into the wall. thats what i do.
drummermitchell
« Reply #4 on: 25 Oct 2010, 11:58 pm »
My 28s are plugged into one Torus and they are never coming out,power in reserve,            definately non current limiting.
They make a huge difference,with the new transformers in the newer sq.amps,you might not need it EXCEPT for the protection the Torus gives.
I'll be doing my transformer upgrade and I know they will be plugging right back into my Torus :thumb:..
95Dyna
« Reply #5 on: 26 Oct 2010, 02:43 am »
I have the Toorus CS15 and the 7BSST2's with the upgraded transformer and capacitors.  I plug the 7B's, BP26, Esoteric X-05, VPI Classic and FM tuner into the Torus.  Compared it to removing the 7's and plugging them into the wall and prefer all plugged into the Torusn overall.
BrysTony
« Reply #6 on: 26 Oct 2010, 03:46 am »
I don't own a Torus but if I did I would plug everything into it.  I am currently using a PS Audio Quintet and everything including my 7BSST2s is plugged into it and it works fine.  Surge and Spike protection is absolutely required where I live.
