Odd frequency response for AV-2
0 Members and 1 Guest are viewing this topic. Read 1268 times.
texanater
« on: 24 Oct 2010, 07:55 pm »
I recently acquired the ultimate analog test lp, and for shiggles tried it live.  There is a test that steps down from 1khz to 20 hz in a total of 30 steps.  On the 15th step which I calculate is about 200 hz, the amplitude drops off quickly by ear.  On the 19th step which I calculate is about 130 hz the volume reaches a minimum.  It sounds up to 10 db off but that is truly a wild assed guess.  I have no way of actually measuring the real amplitude.  The volume begins to come back as the frequency drops.  So, in short there is a significant volume drop between 200hz and 100hz with a min near 130hz. I do not hear the drop when I listen through my headphones. Is this normal?  The speakers sound great and I never noticed this with regular music.  I tried the test on a set of Rogers LS2 and noticed a similar yet much less pronounced behavior. I guess it could be room interaction, but the same drop off occurs regardless of speaker placement.  Very confusing.  Thanks for your thoughts!
texanater
Re: Odd frequency response for AV-2
« Reply #1 on: 24 Oct 2010, 08:07 pm »
I should add that I have a toddler who is fascinated with them and I'ved already had to replace 2 tweeters.  There may be some other damage I can't see. Further, I'm not the most skilled wood worker and could have messed up the cabinets.  Lastly, I stuffed a little bit of foam in the cabinets, not much but some.  Maybe that is affecting things.
Thanks again!
Nate
Danny Richie
« Reply #2 on: 25 Oct 2010, 04:44 pm »
Sounds like room related effects.
Also, the cabinets are best off lined with No Rez and then a loose fill of polyfill or fiberglass insolation behind the woofers.
If not lined with No Rez then a dense layer of polyfill or fiberglass insolation should be used to cover the entire inside leaving only a clear air path to the port.
texanater
« Reply #3 on: 25 Oct 2010, 06:26 pm »
Thanks Danny,
The cabinets are lined with No Res and I added some egg crate foam in the empty area.  It sounds like you are saying there should be a clear air way from the drivers to the port.  Is that right?  Should I remove the egg crate foam?
Room interaction seems reasonable, but its a pretty large 2 story room.  I haven't measured it but its ~12' wide by 20' long by 18' high with a sloping roof.  Does that sound susceptible to loss in the 100-200hz range?
Nate
Danny Richie
« Reply #4 on: 25 Oct 2010, 06:32 pm »
Yeah, I would pull the egg create foam out. That is probably over doing it.
Yeah, the high sloping roof will cause measurement problems. It may not sound bad as the added reflection is heard as a delay, but from a measurement standpoint it will cause cancellation.
