bp25 and +4db sources?
0 Members and 1 Guest are viewing this topic. Read 1485 times.
Rodzilla
« on: 24 Oct 2010, 05:12 pm »
hi there
 first post,have a small technical question i'm hoping i can get answered...i've recently hooked up a pro source to my BP25 that outputs in +4db format...it works but my volume control is really touchy with this source being "significantly" higher than any others...but i was pleased to see provision on the schematic and the BP25 board itself for a +4db pad circuit on the balanced inputs...so i got some resistors and now with pre open....i have a question about installing them...
 do i need to cut the traces on the board to install this?the first 4.6k resistor seems like it would be useless if they are left intact..the trace shorts across it's pads. i suppose a jumper could easily replace the resistor to reverse this "modification" if the pad was later taken out???
it seems simple and easy enough but is this what i have to do here?i need some advice before i make repairable,but irreversible changes to the PCB with a blade here!
  • The Demo is Everything!
    • http://www.bryston.com
Re: bp25 and +4db sources?
« Reply #1 on: 24 Oct 2010, 05:23 pm »
hi there
Hi Rodzilla,
Welcome - please email Mike Pickett at Bryston - [email protected].
james
Stu Pitt
« Reply #2 on: 24 Oct 2010, 08:31 pm »
There's some sort of device you can use to drop the current (or voltage?) coming from a source.  It's kind of like a TV cable ground loop isolator in size.  Relatively inexpensive too.  I can remember specifics, but a friend on another forum had a problem with his CDP's output making volume control on his integrated amp a mess like you're describing.
If I can find it I'll let you know.  In the meantime, maybe Google something like 'reduce CD player output?'
Rodzilla
« Reply #3 on: 24 Oct 2010, 10:38 pm »
so the short answer is...YES,you do need to cut the traces to install the optional +4db pad network on the balanced inputs of a BP25...it works fine,the values given on the schematic appear to be correct and the level is properly reduced,if one ever needs this back to factory a simple wire jumper can bridge the gap in place of the removed resistors and return things to normal
as a standard disclaimer, it should be said that this really is something that should probably be done by Bryston for warranty reasons... a BP25 is not a cheap investment and most would still be under warranty...if you need this installed,weigh your options and impatience to have it done carefully before proceeding...my BP25 is long paid for and my impatience won
 the long answer? this IS simple,a sharp Xacto knife is all you need,the traces in question are easily accessible in wide open spaces and not at all crowded by others,if after looking at the schematic and board, you need more instruction than that,frankly you're in over your head and shouldn't be attempting this yourself...
 being that relatively few people would ever need this modification,i'm grateful that provisions for it were included on the board at all,as this IS the proper place to do this...and i can see why the parts were omitted and the PCB designed the way it was,instead of say just having the unused network installed with some way of switching it in or out ...this way eliminates a few connections in the input path while still allowing for the pad network to be installed if needed...and tho maybe not super elegantly so,it's still removable as well.
 the best part,besides the volume control working normally now is that my source sounds noticeably better as well,it's not on the verge of overloading the preamp which now has some headroom to work with...this has been a good thing
