Reel to reel
0 Members and 1 Guest are viewing this topic. Read 2282 times.
jwes
Reel to reel
« on: 23 Oct 2010, 04:27 pm »
Hey all.  Have a chance to pick up what appears to be a decent old reel to reel. Have no clue on set up.  Is this like turntable and requires a phono amp oe go directly to pre?  Also what's the take on general sound from reel?  Assume a benefit like phono is staying analog.  Just curious about what might be effort vs reward...
Jim
Bill Thomas
Re: Reel to reel
« Reply #1 on: 23 Oct 2010, 06:57 pm »
Hi, Jim!
     First, (as I ALWAYS suggest) when asking for an opinion about a certain piece of equipment, it is MOST helpful if you provide a Manufacturer name and a Model Number.  Reel-to-reel machines were produced at all SORTS of quality levels, from "Washing Machine-sized" professional units (like Ampex machines and others) to portable "tabletop" units that were relatively inexpensive, to simple tape transports that didn't include record or reproduce electronics.
     Generally speaking, it is far more common to find a reel-to-reel machine that *does* have record and reproduce electronics included.  In this case, the Output would feed into a Line Level Input of your preamplifier (like a Tuner or Auxiliary Input).  There *were* several "transport only" decks produced.  I recall a BSR deck from 1965 that cost a grand total of $19.95.  No electronics were included, but at least it DID have the Record/Playback head and an erase head included at that price.  (Hint: It was NOT a "great deck.")
     A reel to reel tape unit isn't as "fiddly" or "fussy" as a typical turntable.  While it DOES require certain maintenance or setup procedures, once set up properly, it can function quite well with only normal head cleaning for months and months on end.  During setup, the tape heads are degaussed, (de-magnetized) cleaned and then aligned to a "standardized" alignment tape.  The electronics are calibrated for the proper "standard" reproduce and record levels and the record bias is adjusted for the tape type you have selected as your "normal" recording tape type.  (Different types of tape require a different bias setting to produce "flat" recording and reproduction response.)
     So how does reel-to-reel recording stack up?  Quite fine, thank you.  Consider that MOST of the music recorded from around the 1950's until the 1990's was originally recorded on magnetic tape, prior to being "mastered" for vinyl on a cutting lathe.  By the same token, reel-to-reel recorders can also be rather abysmal, IF they are compromised by lack of maintenance.  It's also safe to say that the final performance will depend TOTALLY upon the quality of the recording itself.  If YOU are making the recordings, YOU will control exactly how good the final result will be.  If you are depending upon commercially produced tapes, the results can be either VERY good, or BARELY adequate - depending upon the care the duplicator placed in the product being produced.
     There is one thing you will notice:  Tape hiss.  While noise reduction techniques can reduce the overall tape hiss levels, (think dolby-B or dBx noise reduction), most consumer reel-to-reel decks did NOT have these technologies included.  In MOST cases, it would require an external unit to encode and decode the audio.  Most commercially-produced reel-to-reel tapes did NOT include noise reduction - unlike audio cassettes which usually WERE encoded with dolby-B noise reduction.
     I hope this VERY brief "overview" will help you with your question, but PLEASE let us know what make and model of reel-to-reel you are considering.
Sincerely,
Bill Thomas
jwes
Re: Reel to reel
« Reply #2 on: 25 Oct 2010, 10:34 pm »
Bill,
This is really helpful - thank you!  I'll find out more.
Jim
galyons
Re: Reel to reel
« Reply #3 on: 25 Oct 2010, 11:52 pm »
You also need  determine whether you want playback only or record/playback capabilities.   You must also pay attention to your playback media. If you are planning to play commercially pre-recorded tapes determine if you have, if any, 2 track or 4 track stereo tapes.  2 track tapes were the original "home" stereo media and can now be pretty pricey.  The 2 track quality is very fine, bettering LP's in channel separation and, depending on the genre, musical timbre, especially string tones.
4 track tapes are much more commonly available as they were more the direct competition for stereo LP's. The narrower tracks (1/2 as wide a a 2 track), do not provide as high a level of fidelity, but are more convenient, especially with an auto-reverse capable deck.
Generally the play and record amps in R2R decks were pretty dismal.  Think early, gritty solid state.
It is pretty easy to significantly improve the playback with an outboard head amp. (Think phono stage, they are the same except for minor differences in the EQ curves.)
So give us some details to work with.  Who knows, you might be ready for "The Tape Project"!
Geary
