Just bought a VPI HW-16
0 Members and 1 Guest are viewing this topic. Read 1104 times.
kgturner
« on: 23 Oct 2010, 01:20 pm »
So I purchased a 2nd hand VPI HW-16 which should arrive next week. From speaking with the seller, it seems to have been kit upgraded to a HW-16.5. Granted, I only own about 70 LP's right now, but I figure it's easier to clean 70 now than hundreds later. I'll clean new ones as I get them. One question though: How often do most clean their vinyl? Anybody have any tips or advice for a newb on using the machine? Thanks.
Kevin T
PeteG
Re: Just bought a VPI HW-16
« Reply #1 on: 23 Oct 2010, 01:57 pm »
I use a HW-16.5 and only clean once with AI vinyl ceaner ( AI cleaner) that's all, hit it with a good record brush when you put it on. Also get a new vacuum tube for it.
