File format
0 Members and 1 Guest are viewing this topic. Read 1258 times.
joeling39
File format
« on: 23 Oct 2010, 10:50 am »
I have persisted with WAV file format for years. However, I'm beginning to get a little frustrated with the lack of convenience with tags & meta data. What format are most folks using for playback on itunes that has a little more flexibility in terms of metadata but is still lossless ?
Compatibility with foobar & Jriver on PC would be even better.
Joe Ling
Crimson
Re: File format
« Reply #1 on: 23 Oct 2010, 11:36 am »
AIFF. Lossless, uncompressed, and supports tagging.
joeling39
Re: File format
« Reply #2 on: 24 Oct 2010, 11:30 am »
Thanks. What's a good ripper for AIFF ?
planet10
  • Frugal-phile (tm)
    • planet10-hifi
Re: File format
« Reply #3 on: 24 Oct 2010, 08:14 pm »
Max. iTunes.
dave
Bear Heath
Re: File format
« Reply #4 on: 25 Oct 2010, 06:29 pm »
I second Planet 10's approach. Rip with iTunes and if I download a FLAC file then I convert to AIFF with Max. Max is very easy and fast.  I use PureMusic to play the music and iTunes as the database.
joeling39
Re: File format
« Reply #5 on: 26 Oct 2010, 11:23 am »
Thanks guys much appreciated
