0 Members and 1 Guest are viewing this topic. Read 5360 times.
The GamuT SolutionTo achieve the purity and clarity that our clients demand, we have come up with a very simple and very effective solution. We only use one transistor per channel, but a very large one indeed. Using a single massive transistor allows us to tune them to sonic perfection and lay out a much simpler signal path. The transistors we use are massively expensive, but we think it's worth it, and you might agree when you hear our amplifiers perform.
Here you go Richard.... (Denmark)http://www.gamutaudio.com/products/details.asp?id=41
An amplifier stage that uses just one device per channel (transistor, vacuum tube) is simply a Class A amplifier.
A single ended Class A amplifier. A Class A push-pull amplifier requires 2 devices.dave
if there is one output device, there is no debate; it must be Class A.
For an audio amplifier, but in the general case it is not true. For example a single device can run in Class C ... often used in radio transmission.dave
