N3s or N3 Transmission Line?
0 Members and 1 Guest are viewing this topic. Read 2366 times.
Zerogravity
« on: 22 Oct 2010, 07:17 pm »
I was curious if anyone knew which design would sound better and be easier to adjust with a pair of subwoofers (GR non servo sealed 12") Obviously the Transmission Line design is a better choice if one is just listening to 2.0 stereo and this was my original choice, however since I already have 2 subwoofers I could make better use of what I have. I eventually would like to get a servo or 2 and pair them up into I unit by attaching them together. This wouldn't be practical with the towers, however if it is easier to blend the T.L. With the subs, I would just put them along side of each other. Thanks, Jim
Danny Richie
Re: N3s or N3 Transmission Line?
« Reply #1 on: 22 Oct 2010, 07:37 pm »
The lower the crossover point the easier it is to blend them together.
Zerogravity
« Reply #2 on: 23 Oct 2010, 02:13 pm »
Appreciate it Danny! I was a little confused as It seems that some people crossover with a smaller sealed unit, unless it was for a different reason that I didnt understand!
