Some follow up to RMAF discusion about line arrays
0 Members and 1 Guest are viewing this topic. Read 2460 times.
standub
« on: 22 Oct 2010, 02:41 am »
Rick,
I was in your room asking about line arrays sunday at RMAF if you remember, I had a few question I thought of after seeing some other rooms.
1. What's the difference in sound between the SB 5"/7" vs. a Revelator of the same size?  Does it really mater in a line array?
2. Same question but Foundtek ribbons vs. the RAALs?
3. If you had to pick one, which upgrade would you go with?
Thanks.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: Some follow up to RMAF discusion about line arrays
« Reply #1 on: 23 Oct 2010, 01:52 am »
The Scan drivers offer a little more detail and smoother response. If I were to choose I would probably lean towards the RAAL ribbon because it can cross lower than the Fountek.
