micro-acoustics microstatic tweeter arrays
0 Members and 1 Guest are viewing this topic. Read 3692 times.
les winter
« on: 21 Oct 2010, 04:03 pm »
I'm looking for 1 or 2 microstatic tweeter arrays.  These are the MA-1 made by micro-acoustics.
Anybody got one  or two?
*Scotty*
Re: micro-acoustics microstatic tweeter arrays
« Reply #1 on: 21 Oct 2010, 06:06 pm »
I can't find a Micro-Acoustics MA-1 I did find an article on Micro-Acoustics see link below:
http://www.roger-russell.com/sonopg/micropg.htm
It mentions the MS-1 high frequency array which used 4 Peerless cone tweeters. You could DIY this using 4 tweeters from  Parts Express http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-965  4 or more and you pay $3.15 each
A simple cap in series for a 6dB/oct. crossover and you're done.
Scotty
les winter
« Reply #2 on: 21 Oct 2010, 06:22 pm »
Thanks Scotty.  these things turn up every few weeks.  Actually I have a pair and an orphan.  I use the pair up front for my HT on top of large Advents.  My rear large advents could use a pair as well.  The originals used two different sized tweeters.  If I can't find a reasonable pair I may take your advice and build something my self.
thanks again.
les
