USB Cable of Choice from Mac to DAC?
0 Members and 1 Guest are viewing this topic. Read 1257 times.
morganc
« on: 21 Oct 2010, 04:17 am »
Is there any consensus on a good, inexpensive (Less than $100 is ideal) USB Cable to use for running from the Mac to the DAC? What about the Firewire cable from the the External Hard drive into the Mac?  I am using a Mac Mini.  I was looking at the Kimber USB Cable...thoughts?
Thanks in advance,
Morgan
writeface
Re: USB Cable of Choice from Mac to DAC?
« Reply #1 on: 21 Oct 2010, 05:14 am »
Wireworld Starlight USB 80 bucks I think.
low.pfile
« Reply #2 on: 21 Oct 2010, 06:01 am »
Consensus? Ha? that's like getting a consensus on pizza toppings.
And it is DAC dependent....some DAC manufacturers say it doesnt matter. Length of cable is a factor as well.
bombadil111
  • Hawthorne Audio, MiniWatt N3, Music Hall DAC 25.3
« Reply #3 on: 21 Oct 2010, 06:32 am »
The Starlight is $80 for the 1m length.  If you want longer, price goes up quickly.  I whent with this one from Wireworld, the Utraviolet at about half the price.  Galen Carol seems to have the best price on these.
https://www.gcaudio.com/cgi-bin/store/showProduct.cgi?id=539
