New computer to Airport Extreme Setup
0 Members and 1 Guest are viewing this topic. Read 1875 times.
jtwrace
    • TIPP YouTube Channel
« on: 21 Oct 2010, 01:43 am »
I just unpacked and got two new laptops going for home use.  I use an Airport Extreme.  How do I enable printing through the extreme on these laptops now?  Do I need to install the Extreme software or???
skunark
Re: New computer to Airport Extreme Setup
« Reply #1 on: 21 Oct 2010, 02:04 am »
Is the printer connected to the airport extreme via usb port?  Then you need to use the airport utility to set up the printer on the airport extreme.  If the printer is wired/wireless then the airport extreme isn't involved.
jtwrace
« Reply #2 on: 21 Oct 2010, 02:08 am »
Yes, printer is plugges into the USB on the extreme.  Printer is setup through the Mac Mini already but I want to add the laptops for wireless printing.  I need to use the airport utility disk huh?
skunark
« Reply #3 on: 21 Oct 2010, 02:16 am »
if it's already set up on the airport extreme then just add a new "bonjour" printer on each laptop.
jtwrace
« Reply #4 on: 21 Oct 2010, 02:27 am »
Got it!   :thumb:
Crimson
« Reply #5 on: 22 Oct 2010, 11:35 pm »
And don't forget to set up a discreet 5GHz net with Airport Utility (Airport >> Wireless >> Wireless Network Options). It will run your n-connected devices much better.
jtwrace
« Reply #6 on: 22 Oct 2010, 11:45 pm »
Does this get done on each device or through the main computer that I use to manage the Airport Extreme?
Crimson
« Reply #7 on: 23 Oct 2010, 12:03 am »
Assuming you have the dual-band Extreme, you need to first set up the 5 GHz network as I described above using Airport Utility. Then tell each n-enabled device to join that network. The encryption and password will remain the same.
jtwrace
« Reply #8 on: 23 Oct 2010, 12:05 am »
Yes, I have the dual band router.  I've got all the devices on the network but guess I need to check and see if they are all on the "N" network.  Do I check from the utility from each device or my Mac Mini that I use to admin the Extreme?
Crimson
« Reply #9 on: 23 Oct 2010, 11:47 am »
First, using Airport Utility from ANY machine on your network, make sure the 5 GHz network is ENABLED on your Extreme. Click on the Airport tab, then select Wireless, then Wireless Options. Name your 5 GHz network (must be a different name than your main network). Click ok, and then update your Extreme.
Once your Extreme is updated, go to EACH individual machine that is n-capable and join the new 5 GHz network that you just created (assuming all your machines are Macs, go to System Preferences >> Network, or just click on the wifi icon in the top right, and join this new network).
By doing this, all n-capable machines will run at 5 GHz while everything else will be on the 2.4 GHz network. You are essentially running two separate networks.
jaywills
« Reply #10 on: 23 Oct 2010, 12:29 pm »
Thanks very much for the 5 GHz setup tip.  I just got an Airport Extreme and had not picked up on it just from reading the instructions.  Cordially,
jtwrace
« Reply #11 on: 23 Oct 2010, 12:56 pm »
Got it!
 :thumb: :thumb:
