0 Members and 1 Guest are viewing this topic. Read 5689 times.
just disconnect the bass drivers from the passive xover, and run them active from the deqx, and leave the connection w/ the mid/high as it is connected now with the stock passive crossover?????
do you have tom's email address ?if you could pm it to me , i will try to contact him directly.i did not have any luck when i asked for the xover points through his webpage contact , but perhaps he is more open when contacted directly.
thanks Andysorry that that is not clear from left to right on the component side :black white is tweeterblack blue is mid black green is bass (two drivers in parallel)black red is input.from the other side of the board its the opposite :from left to right :input , bass , mid, tweetthanksmalcolm
www.erseaudio.com has a crossover calculator tool you can play with. You can look at parts layout and values on your crossover, plug them into the calulator and try to back into the crossover frequency and slope.Russ
