Rogue Cronus Magnam -Speakers?
0 Members and 1 Guest are viewing this topic. Read 4960 times.
sacad
« on: 14 Oct 2010, 03:35 am »
Decided to go with a Rogue Cronus Magnam.  My room is 15w x 20l  x 8 - sitting accross the width end.
Can someone suggest a good pair of speakers that match and will sound clear not overpower the room with too much bass.
Also will need a decent DAC to match this amp.
Just moved in so the room is pretty empty so far with a couch and TV hard wood floors. that it.
Best regards
  • Speakers....What Speakers ?
Re: Rogue Cronus Magnam -Speakers?
« Reply #1 on: 14 Oct 2010, 03:44 am »
Budget....and music preferences....?
(Rogue Cronus Magnum-90WPC-Tubed Integrated Amplifier)
« Reply #2 on: 14 Oct 2010, 03:53 am »
And, space?  How much room do you have?  Room for floorstanding speakers?  Or only bookshelves?  Room for subs?  And will you eventually do more room treatments?
« Reply #3 on: 14 Oct 2010, 04:13 am »
For bookshelves I'd rec the Geddes speakers, and for floorstanders the GR Research V1 or V2.
« Reply #4 on: 14 Oct 2010, 04:14 am »
What speakers have you heard....and what have you owned ?
« Reply #5 on: 14 Oct 2010, 04:32 am »
I've read the reviews also....looks like a solid amp. You have 90 watts...there are many choices.
You can check the Circles here...(for $2,000.00 range)...to get an idea of what they have to offer...
Aether Audio
Daedalus Audio
GR Research
Omega
Odyssey
Salk
VMPS
Selah Audio
http://www.audiocircle.com/index.php?action=circles
Ericus Rex
« Reply #6 on: 14 Oct 2010, 12:14 pm »
The only speaker I have heard with the Cronus Magnum is the Nola Boxer monitor.  I thought the two matched quite well.  I think they're $1,500/pair w/o stands.  Good bass response too even for their size.  90 tube watts is enough to drive nearly every speaker so don't worry too much about speaker sensitivity.  With a question like that you'll likely get everyone's favorite speaker for under $2K with very few having actually heard the combo.  While the Nola is not my favorite speaker for under $2K I have spent some time listening and enjoying the pair.
As for DAC, I think the best bargain in cheap dacs right now is the Beresford at $279.  There are a number of sub $1K dacs I haven't heard yet.  But I have directly compared the Beresford to the Oppo 83SE (which competes with $3-4K players) and the little dac kept up with the competition.
Keep us informed!
Ericus Rex
« Reply #7 on: 14 Oct 2010, 12:18 pm »
Great little amp btw    :thumb:
HAITIMAN
« Reply #8 on: 28 Nov 2010, 12:40 am »
Best regards
I have matched a pair of Salk Songtowers with a Rogue Cronus Magnum in a room of similar dimension. Highly recommended. Try some NOS RCA cleartops for a little extra depth to the soundstage.
Ericus Rex
« Reply #9 on: 5 Dec 2010, 05:09 pm »
I saw a Cronus Magnum recently and it was actually factory fitted with what appeared to be RCA Cleartop 12AU7s.  SCORE!
