Pioneer DV717 DVD PLayer
0 Members and 1 Guest are viewing this topic. Read 921 times.
Puffin
« on: 12 Oct 2010, 08:03 pm »
I picked up the above player from an Audiojumble at the weekend. It does not have a remote control. The Dig Out appears to be controlled by the remote. Does anyone have this model or another Pioneer DVD player that has a remote which operates the Dig Out ?
I have a learning remote and would only need to borrow it. If anyone in the UK can help.
Rob.
bpape
    • Sensible Sound Solutions
Re: Pioneer DV717 DVD PLayer
« Reply #1 on: 12 Oct 2010, 08:38 pm »
This is likely your best bet - a search for universal remote files which use the DV717
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?start=&num=0&kw=dv717&area=
Bryan
