Beginner: Bryston 470 mono Amp Question
0 Members and 1 Guest are viewing this topic. Read 5023 times.
mauric72
« on: 8 Oct 2010, 03:17 pm »
Hello Together
Possible the Bryston 470 it's this a good amp?, to drive a Center are this a good solution ?. it's possible this playing in higher quality level near a Mcintosh?, Nuforce ?.
it's also possible to become the schematic informations from this amp or i need to write this to the tecnical part of Bryston company?.
Possibilites to switch from, 110/240volt Exist also ?
for any kind of informations i'am happy
thanks and best regards from switzerland
MC
__________________
McIntosh: C 45 / MC 352 / Thorens TD 320 / MR 78 / Marantz SACD 11S1 / Dynaudio
  • The Demo is Everything!
    • http://www.bryston.com
Re: Beginner: Bryston 470 mono Amp Question
« Reply #1 on: 8 Oct 2010, 03:44 pm »
Hello Together
MC
__________________
Hi mauric72
The 470 is a mono 70 volt line amp - you can use in a normal stereo setup on the 8 ohm output. We can not switch the voltage.
james
mauric72
« Reply #2 on: 8 Oct 2010, 07:44 pm »
Thank you for your anser.
Did you mean, there is no chance to switch the voltage?
Perhaps somebody else can switch it?
Thanks in advance for your reply.
Nice greetings
MC
« Reply #3 on: 8 Oct 2010, 07:46 pm »
Nice greetings
MC
Hi MC - it uses a different transformer for 120V/60Hz or 240V/50 Hz.
james
mauric72
« Reply #4 on: 8 Oct 2010, 08:11 pm »
Hello james
thanks for your quick answer, i am not sure if the transformer can be switched or bridged to running in "situativ" 120/240 voltage?.
situation now:
1inductor x 120 = 120 Volt (USA / Canada / Asia)
what i need:
2inductor x 120 = 240 Volt (Europe)
in the past i did allways used this way to change the transformervoltage.
Please let me know, if you are sure, is possible to do.
Nice greetings
MC
« Reply #5 on: 8 Oct 2010, 10:26 pm »
Hi MC - email service at [email protected] and Mike will assist you.
james
mauric72
« Reply #6 on: 12 Oct 2010, 10:48 am »
Please james, i don't become any Answer :-( ... i'am impatiently?.
Best Regards
MC
Stephen L
« Reply #7 on: 12 Oct 2010, 04:55 pm »
Hi MC,
   It was a holiday weekend here in Canada (thanksgiving), you will probably get a response shortly.
mauric72
« Reply #8 on: 16 Oct 2010, 06:14 pm »
Stil no Answer..... :-(
Best Regards
MC
« Last Edit: 16 Oct 2010, 11:10 pm by mauric72 »
« Reply #9 on: 17 Oct 2010, 01:39 pm »
Best Regards
MC
Please email Brian Russell at Bryston.  [email protected]
james
