Wall Mount for 626 and Dipole speakers
0 Members and 1 Guest are viewing this topic. Read 1830 times.
John Casler
« on: 7 Oct 2010, 11:54 pm »
Since the VMPS 626 in its various forms and the VMPS Dipoles "do not" come with wall mounting provisions or hardware many ask what mounting brackets or hardware we suggest.
Due to their weight many end up using high stands or shelves, which is a good choice.
Because of their weight some even use the mounting brackets for small TV's successfully.
But if you want to actually wall mount either of these models I came across this device that can make it quick and simple.
It is from Parts Express and is rated up to 60#.  It does require that you drill into the rear of your cabinet, but that is the only option if you want wall mounting. (unless you use the TV mounts)
It is called the Hangman ASM6-2-B Speaker Hanging Kit and it costs LESS than $10 :o :o
Looks like this:
