Speaker Mounting Question (help!)
0 Members and 1 Guest are viewing this topic. Read 1314 times.
witchdoctor
« on: 3 Mar 2004, 03:11 am »
Hi,
I have two heavy monitor speakers that need to me mounted near the ceiling for HT. They are Paradigm Active 20's with internal amps. Any suggestions?
Marbles
« Reply #1 on: 3 Mar 2004, 03:17 am »
I'm having a local cabinet maker make me very simple pieces from veneer covered mdf.
These pieces will be about 1" wider than the speaker, and 2" deeper.  They will have a lip on the front so the speaker can't slip off when angled down.
These will have an "eye" bolt in each corner.  I will sink "eye" screws into the ceiling joists and then attach the eye bolts to the eye screws with nylon ribbon.  I can adjust the angle by the lengths of ribbon.
So basically I will have a flat piece of wood with a lip on the front and eye bolts on each corner.
Should be very easy and effective.  Total cost of the project will be in the $50-60 range  :D
witchdoctor
« Reply #2 on: 3 Mar 2004, 03:19 am »
I will try and find a local guy, great suggestion!
