*SOLD*FS or Trade-Tannoy System 1200
0 Members and 1 Guest are viewing this topic. Read 2235 times.
klipschfan
« on: 7 Oct 2010, 12:24 pm »
Pair of Tannoy System 1200 monitors (black) for pick up in Connecticut. 9/10 condition. Outstanding monitors. Sound almost like a cross between Thiel & Klipsch Heritage. Any questions please email-Thanks!.
$1100.00 for the pair.
Will consider trades for a DAC/Amp/Pre from McIntosh/Meridian/Wyred4Sound
FEATURES
The System 1200 reference monitor is capable of accurate reproduction at very high sound pressure levels. It can be used as either a mid-field monitor or as a main monitor in smaller studios. The computer-optimized reflex cabinet uses a Tannoy 12" Dual Concentric™ drive unit, giving a frequency response down to 40 Hz. Because the Dual Concentrics high frequency dome is located at the acoustic center of the low frequency cone the unit behaves as a single point source, mirroring the way sound is produced in real life. In addition, the natural directivity control allows a ninety-° dispersion pattern, minimizing reflections within the listening environment. The System 1200 cabinet uses a 1 1/2" thick MDF front baffle to provide a strong structural foundation for mounting the drive units and increase overall cabinet rigidity. Internal cabinet cross bracing further stiffens the structure, meaning a tight and fast low frequency response with low distortion. Applications for the System 1200 include audio visual, broadcast and post-production facilities as well as music studios and quality control applications. Like all System Series monitors magnetic shielding is available as an optional, allowing use in close proximity to video monitors.
PERFORMANCE
Sensitivity 95 dB / 1 W @ 1 m (half space)
Nominal Impedance 8 ohmsFrequency
Response ± 3 dB 40 Hz - 20 kHz
Power Handling (RMS/Programme) 180 / 350 Watts
Recommended Amplifier Power 100 to 300 Watts into 8 ohms
DRIVE UNITS
Driver Type 12" Tannoy Dual Concentric™Dispersion 90° conical
CROSSOVERFrequency 1.3 kHz
CONSTRUCTION
Enclosure Type Optimized bass-reflex loaded
Volume 74 LitresDimensions 15.59" x 25.55" x 16.06"
Weight 59.5 lbs
Finish
Charcoal soft texture baffleGrey suedette vinyl sides and back
« Last Edit: 9 Nov 2010, 11:30 am by klipschfan »
sniper6868
Re: FS or Trade-Tannoy System 1200
« Reply #1 on: 9 Nov 2010, 07:41 am »
HI !
Do you still have the Tannoy system 1200?
thanks
klipschfan
« Reply #2 on: 9 Nov 2010, 11:29 am »
The Tannoys are sold.
