0 Members and 1 Guest are viewing this topic. Read 1331 times.
Hello all,I would like to try connecting my BP5 preamp to my 4B amp using the balanced connections, but the 4B uses a 1/4" male input. It looks like I can buy a cable that has the 2 different connector styles (XLR to 1/4") but will using that make the connection unbalanced and no different than using the RCA style unblanced connections? Hmmm..Hopefully someone can shed some light on this....thanks!
Hi James,I believe this is an older Pro model (serial # 48706), which only has a 1/4" male input, no XLR connection. If I used a XLR to 1/4" cable, is that no longer a balanced connection?Thanks
