Faceplates
0 Members and 1 Guest are viewing this topic. Read 2783 times.
Randy
Faceplates
« on: 1 Mar 2004, 10:43 pm »
I don't want to bother Klaus, but does anyone know if the faceplates on the Stratus is easily replaced?  Is it something a technically challenged novice like myself could do with a Phillips or something?  My Extremes are in Burgandy, but I now feel the need for Silver or Black instead.  If it means sending them back to Klaus I wouldn't do it.
mgalusha
Faceplates
« Reply #1 on: 2 Mar 2004, 12:56 am »
Randy,
The faceplates are not hard to change. You need several sizes of hex wrenches (otherwise known as Allen wrenches) and a little patience.
Basically you just remove the top - 6 bolts, remove the LED's - 2 bolts and then remove the 4 bolts holding the faceplate on. Put it back together in reverse order.
Of course be sure they are unplugged, getting zapped is never fun. :D
Mike G.
Randy
Faceplates
« Reply #2 on: 2 Mar 2004, 01:49 am »
Thanks, Mike.  Sounds easy enough.  I may try it.
Randy
KarlDL
Faceplates
« Reply #3 on: 3 Mar 2004, 01:43 am »
A miniature rachet wrench and hex (Allen) bit comes in VERY handy when dismantling any part of the Stratos case.  Some of the Allen screws are very hard to reach.  Patience is always a prerequisite, in some cases beer is another essential  :wink:
djbnh
Stratos case
« Reply #4 on: 3 Mar 2004, 11:13 pm »
However, beer leads to scratches.
   And there's no Stratos case patches.
So be real patient,
   Or cry over your scratch/dent.   :P
Bob A (SD)
Faceplates
« Reply #5 on: 4 Mar 2004, 01:48 am »
Randy,
  Which are you going with?  Flat or gloss wet black?  Or silver like mine?
--Bob
Randy
Faceplates
« Reply #6 on: 4 Mar 2004, 03:01 am »
Hi Bob,
   Just giving it some thought right now.  I sure like the look of your silver ones, though.
Randy
Faceplates
« Reply #7 on: 4 Mar 2004, 11:47 am »
Platinum, baby  :thumb:
Randy
Faceplates
« Reply #8 on: 4 Mar 2004, 10:31 pm »
Max,
  Didn't know platinum was available.  Sounds interesting.
http://www.harmonicdiscord.com/gallery/drphoto?&page=1
