GedLee Abbey's Feedback Wanted!
0 Members and 4 Guests are viewing this topic. Read 383684 times.
mgalusha
Re: GedLee Abbey's Feedback Wanted!
« Reply #160 on: 6 Oct 2010, 03:26 pm »
Well that is a bummer that the DCX 2496 is required!  I would love to have a somewhat simpler system.  I realize that by it's very nature, the Abbey/Multi-Sub approach is more complex than others I would just like to be able to have fewer "boxes" to deal with.
A DCX is absolutely not required. I have the subs using speaker level inputs, both channels to each sub, so they are summed. I used the servo amps with parametric EQ, so I get some additional flexibility in tuning though not as much as the DCX would provide. Of note, I have two dcx's, one stock and one very modified so it's not like I can't go that way. :)
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
« Reply #161 on: 6 Oct 2010, 03:50 pm »
I found that using the Dodd buffer "preamp", in front of my integrated amp, helped the multiple subs noticably.
I also use a pair of dual ob servo subs. and I have a sealed servo as well, (but don't use it for this, but can if want some more impact)
-Tony
dwr
« Reply #162 on: 6 Oct 2010, 04:06 pm »
Great explanation Doug, There really is a little more to it than just putting three active subs in the mix and calling it a day. Active subs are fine but the DCX really gives you a serious amount of versatility, for $300.
dwr
« Reply #163 on: 6 Oct 2010, 04:09 pm »
And as Mike points out, there are a number of ways to achieve the proper end result. Thats part of what makes this hobby fun!
TomS
« Reply #164 on: 6 Oct 2010, 04:41 pm »
I use the DCX to drive the Rythmik line level inputs since Brian Ding and Ralph Karsten both advised against routing speaker level inputs from the M60's to the 3 plate amps (1 RCA, 2 XLR versions).  The M60's have "floating" balanced outputs and there was concern that connecting to the Rythmik would cause the M60 negative speaker terminal to be grounded at the plate amp shield side.
Have you been able to work around that in your setup or is it not really an issue?  I'd prefer to drop out the DCX as well as I'm not using much EQ at all.
Tom
AJinFLA
  • Soundfield Audio Loudspeakers
    • Soundfield Audio
« Reply #165 on: 6 Oct 2010, 05:22 pm »
AJ,
I don't think that Gedlee owners are not willing to audition but more so that ownership is not widely spread as of yet.  Orion's went through a very similar growth before notoriety was gained.
Wasn't my intent to imply that. I realize the Orions have been around longer and are more widespread (which is why I included the date when I heard them). It was just an observation.
I would have gladly offered you an audition when I was still in NC.
Thanks. Would have been a bit of a haul, but better than Detroit I suppose  :wink:.
cheers,
AJ
jtwrace
    • TIPP YouTube Channel
« Reply #166 on: 6 Oct 2010, 06:16 pm »
-Tony
I guess what I'll do is make a "Y" from the output of my Dodd Buffer and one pair to the mono block amps for the Abbey's and one pair to the active crossover for the four subs.
mgalusha
« Reply #167 on: 6 Oct 2010, 06:54 pm »
Tom
Tom, on my servo amps, A370 PEQ, they speaker negatives are not grounded, they are about 100ohms to ground, same as the hot side. I checked them prior to ever hooking them up to a floating amp. I'll check them again to be certain but I'm pretty sure that is the case. If not, it would be easy to build a circuit to do this.
brj
« Reply #168 on: 6 Oct 2010, 10:22 pm »
It seems as if almost everyone owns the Abbeys or Nathans.  Are there any Summa owners out there?  I'd love to see some high quality photos of the Summa, both close up and in-room, to get a feel for just how large they are and their fit and finish.
Wayne1
« Reply #169 on: 6 Oct 2010, 11:02 pm »
How 'bout this one, Brian?
brj
« Reply #170 on: 6 Oct 2010, 11:27 pm »
Quote from: Wayne1
Yep, that was the only image I've seen, which does give a sense of scale (large!).  I believe that Earl has changed his cabinet construction and finishing process since then, however, so I'm not sure how similar current versions appear vs. what is shown.
dwr
« Reply #171 on: 6 Oct 2010, 11:38 pm »
Wayne, how old is that picture??
brj
« Reply #172 on: 6 Oct 2010, 11:50 pm »
2005
Link:  http://nfp.cba.utulsa.edu/bajaja/FreeAudioReviews/Reviews/AudioMeets/GPAF2005/ReviewGPAF2005.htm
(I performed a Google image search before I made the initial post, and that was the best of the very few pics that I found.)
TRADERXFAN
    • GALLERY
« Reply #173 on: 7 Oct 2010, 12:17 am »
The only other pair that I have seen pictures of were from a guy on the diyaudio board and they predated this version of the speakers.
Geddes says Summas are better, but cost a lot more and are a lot bigger for small performance advantage.
Anand, didn't you see the summas? I thought you had taken some pictures on your visit as well...
-Tony
jtwrace
« Reply #174 on: 7 Oct 2010, 12:48 am »
How long does it usually take Dr. Geddes to reply to email?  It was super quick and now it's been 3 days.   :(
Wind Chaser
« Reply #175 on: 7 Oct 2010, 01:01 am »
3 days is nothing.  If it was weeks, that would be another story.
goskers
« Reply #176 on: 7 Oct 2010, 01:13 am »
Earl may be in china at the moment.
I have some pics that I can pm of the summas. They are large but only as big as they need to be. That being said, I don't think anyone has ordered summas in some time.
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #177 on: 7 Oct 2010, 01:26 am »
To be honest fellas, the Summas are just as big as the pictures above, sans ports! The dimensions are on his website. Truly giants especially if you call them 'monitors.' They are literally control monitors, they keep you captivated in space! Any pictures I have are in my gallery and the only thing I remember there are some very early Nathans.
With the new poly construction, and woofer mounting from the rear which hides the screws, Earl's constructions have gone another step up.
Earl goes to China often but he will reply, I've never waited more than a week.
Anand.
« Reply #178 on: 7 Oct 2010, 01:39 am »
The only real issue I see w/the speakers is the whole WAF factor.  I wonder if a few small changes could be made to make them a lot better in this area.  Maybe make them floor standing by just extending the cabinet down a bit with a solid wood (or solid MDF) extension toward the floor, and a grill cloth to hide those drivers and foam.  Then just veneer the sides and back to give a furniture quality look.  I bet that would make them much, much more likely to pass the WAF test.
jtwrace
« Reply #179 on: 7 Oct 2010, 01:40 am »
Who needs WAF for the man cave?   :lol:
Not me!
