0 Members and 1 Guest are viewing this topic. Read 13777 times.
The GedLee's are optimized for small rooms according to their white paper and online design descriptions. They look awfully small, and integrating 4 (!) subs into the sound is a recipe for tedious trial and error with potentially disappointing results, I would think. I had a sub, and I got rid of it as soon as I got better amplification and transmission line speakers.In the price range of the GedLees, you could consider some Salk HT2-TLs. With one of Jim's custom veneers, they would really like great in that space. If you give Jim Salk a call, he would be happy to give you sound advice about filling a big room (with great sound).If you run them with a Wyred4Sound STP-SE and a pair of SX-1000 monoblocks you would have all the juice you need. I just upgraded to the STP-SE, and it would be great for a large room because aside from excellent transparency it has amazing timbre that will really make the music sound real and natural. The monoblocks will give you excellent imaging.Well, have fun with it!
as my first preference in a living space is sound of my audio system, (and i don't care much about a tv screen), my first choice for speaker location would be where the blue squares are; then, possibly i'd consider the red squares, in either case, the listening position would be where the bigger red square is. all this +/-, of course, depending on the actual situation in the room. for sure, i'd have the backs of the speakers at least 4' from the rear walls, preferably 6'. and the listening position as far back as possible, w/o getting to close to the stairwell - which might need some absorption on it. http://www.danleysoundlabs.com/tapped_horn.asp?MODEL=DTS%2020doug s.
For subs I would suggest the Danley DTS-10 rather than the DTS-20. Here is a quote from their website: Rod
How much do these cost?
That room has a ton of possibilities given a proper setup. The size is such that we'd actually look at it from the standpoint of large room acoustics rather than small room acoustics. ie - skip the bass control and work on developing a bass wavefront and minimizing slap echo and parallel surfaces.Some of the things mentioned already will work fine. The windows and the asymetric location of your setup will still be problematic.The only places I would really address serious absorption assuming the existing location are:- left wall to give better symmetry- left front corner to minimize the corner loading of just one side- peak of the ceiling to minimize horn effect.other than that, just work on breaking up large, flat surfaces.Bryan
Getting the room's reverberation time (the time it takes for sound to decay) down into the range for high quality music reproduction is going to be tough without spoiling the aesthetic. I can image you are probably suffering from poor clarity and definition as a result of the long decay times.You have virtually no absorptive surfaces in there as far as I can tell, does it sound 'echoey'?One of the issues with a space like that is you can treat around the listening position to get a reasonable decay time in that space but you will tend to get an audible echo from the rest of the space which is untreated. So you will need to position absorption around the room. Doesn't necessarily have to be panels, could be soft furnishings, rugs, window treatments, etc. You will still have a longish decay time though because of the amount of untreated ceiling surface area.
James,First, let me join the chorus of complimenters on your digs. Simply wonderful.I have some of the same problems you do. My main room is 22' long and a few inches over 10' across, with a ceiling that goes from 11' to 16'. The house is 1914 Craftsman bungalow, with _a lot_ of tall windows. I wont add room treatments. Also have the original wood floors.My high ceiling just sucks the room dry. When I tried to compensate by turning up the volume, the wood floor starts to be a problem.This evening, I decided to remove the back feet from the speaker cabinets, put a little felt pad on along the back edge where the speaker cabinet would (now) make contact with the floor, and see what would happen.It fixed all of my problems: lack of bass response, bloom at certain frequencies, dead response at others; sound stage improved, along with height imaging that I didn't have previously; the room has good fill, and it sounds great in other parts of the house.Tilt measures at 11 degrees. A No-Cost tweak, and I have almost got a "I just got a whole new music collection" level improvement out of the deal.I don't know if tilt will help with what look like open baffle speakers. I would try it. The brick should help you out, and the tin is so high up, I don't think it will be a problem.If you are going to go to different speakers, I would be looking at surface area of the drivers (the more area, the better), and possibly go with electrostats.I think you biggest problem is in catering to the video. You are going to have a very hard time filling that room from the corner.I hope you find a solution.Mike
if you're concerned about asthetics you can purchase wicker/rattan baskets or hampers, line them with rockwool and use them as planters, etc... fairly unobtrusive vs. dedicated acoustic treatments and easy to move around
I'm just wondering - from an acoustic point of view, why would Abbeys be any better than CS2's? The CS2 has dipole woofers and a waveguide tweeter, and should therefore have high directivity across the band to increase direct-to-reverberant ratio (per Linkwitz).
I actually manufacture a wool carpet padding that is about 1/2" thick and has a density of 40 oz per square yard (3' x 3' piece). I wonder how I could incorporate this?http://www.earthweave.com/padding.htmlI have often thought it would be good for some acoustic panels.
Mike,Yes, the speakers are open baffle and I currently have each of them sitting on square pieces of granite from counter top sink cut-outs. I was trying to do this to give it a good foundation. I also have the speakers at about 4' out from the back wall. As the Emerald Physics CS2's have the crossover controlled by the Berhinger with several room settings, I have chosen the 6' setting. I felt like this produced better bass, although not really enough.Electrostats would be cool but they are just so inefficient for the most part that I worry they would never get to the sound. I did consider the Magnepan 3.6 and then a few subs but the GedLee Abbey's seem to be a much better option. They are said to play at EXTREMELY high volumes. Something I do not think electrostats will be capable of.
Get some "Art" to hang on the walls that is made of cloth and has absorptive material inside the frame.
