FS: TTWeights turntable weight & VPI clamp (and Grado Statement Reference)
0 Members and 1 Guest are viewing this topic. Read 1287 times.
doctorcilantro
Went on a buying spree and these are extras up for sale.
Stock photos; please bear in mind my has some light scratches from use on the underside and general wear. I will get actual pics asap. These are out of stock. It is very heavy. I have one like this I am keeping.
TTMiddleWeight Record Clamp, Weight Style (2.24 LB/1050 Grams) Brass - $70 shipped
Material and Engineering Summary:
1. Low Profile universal fit for all medium duty well built turntables
2. Provides a mass dampening approach
3. Machined from 4 lb billet BRASS High Grade Bar stock
4. Dimensions: 3.45 inch diameter by 1.2 inches height
5. Weight: (2.24 LB/1050 Grams)
6. Minimum spindle height 1/8
More info here.
Ordered this VPI Delrin clamp by accident and it is en route and I believe it needs the threaded VPI type spindle. Comes with washer to mount under LP $65 shipped
I also have a Grado Statement Reference1, new, which I sent toGraod after a week as the generator housing was pretty misaligned. Not a huge deal but I'm glad I sent it in as I moved to another cart. So you'll get cart fresh from Grado. I'm asking 1225 shipped.
feedback
orthobiz
Pics? Will this work on the VPI HW-19 Mk III?
Paul
doctorcilantro
I'll get you a pic asap the black one above is a VPI compatible clamp and the other is just a weight which should also work according to the site IIRC.
The black one has a threaded hole inside for the VPI, and this
pics is an actual pic btw; I'll get you one of the underside. The ttweights pics are stock photos, mine shows slight wear.
« Last Edit: 2 Oct 2010, 10:35 pm by doctorcilantro »
doctorcilantro
doctorcilantro
Some Brasso would clean it up nicely if desired:
