Is using only one channel of stereo amp OK?
0 Members and 1 Guest are viewing this topic. Read 2450 times.
emilostan
« on: 1 Mar 2004, 04:41 pm »
I bought a used amp (stereo not mono but I think it only has one power supply).  Can I safely use just one channel of it for the center channel and not use the other channel (for now).  Will this cause stress on the amp?
Marbles
Re: Is using only one channel of stereo amp OK?
« Reply #1 on: 1 Mar 2004, 04:44 pm »
Quote from: emilostan
You can with no problem.  Keep in mind you can also send it to Odyssey and for a small fee have both channels bridged to form a very powerful and nicer sounding mono amp for that center channel.
emilostan
« Reply #2 on: 1 Mar 2004, 04:52 pm »
Marbles - Thanks, I thought about the conversion but wanted to hold off for now.  I listen to more two channel than 5 channel and want to keep my options open for 6 or 7 channel. It is good to know that I will be safe
Carlman
« Reply #3 on: 1 Mar 2004, 06:47 pm »
Could you effectively make it a bridged mono by first doing a Y connector to the amp's inputs and then run + from left and the - from the right?  Or is it not setup to be run like that?
Rob Babcock
« Reply #4 on: 2 Mar 2004, 02:33 am »
AVA makes a bridger designed to do just that.  I have an X-over that is also capable of doing it.
