lite dac-ah mods?
0 Members and 1 Guest are viewing this topic. Read 3143 times.
siava1018
lite dac-ah mods?
« on: 28 Sep 2010, 04:30 am »
im alredy running my dac-ah on batteries and have done the passive mod, any other mod suggestions?
Puffin
Re: lite dac-ah mods?
« Reply #1 on: 28 Sep 2010, 11:26 am »
Have you done the resistor mod?
siava1018
« Reply #2 on: 28 Sep 2010, 02:23 pm »
No ive herd about it but dint see a write up, do you kno where i can find one?  Also is it worth changing the caps on the board?  Btw my dac is running at 8v.
Puffin
« Reply #3 on: 29 Sep 2010, 10:16 am »
It seems that if you run it at 8v you don't need to change the resistors.
http://www.head-fi.org/forum/thread/198589/circuit-error-in-lite-dac-ah-easy-fix
siava1018
« Reply #4 on: 4 Oct 2010, 08:20 pm »
ok so i lied, i did the passive mod and battery this weekend and now i have heavy distortion mostly in the mids and highs, is it possible i over heated something when removing the rectifiers or when i soldered the caps on?  Also i followed this pic that had the caps hooked up to r36 and r35 then i saw another one where they used c12 and 13 i tried both.  Im using dayton 2.2uf 1% caps from PE.
