0 Members and 1 Guest are viewing this topic. Read 6864 times.
I have wondered for a while if I would be satisfied in the bass department with something like these...How would you describe the bass response on the M60 MKIII's???
Drop a note to member Larkston Zinaspic for details. He went from Plinius SA-100 mk3 to Atma-Sphere S30. He runs Audio Kinesis Jazz Modules speakers, and I know he is very happy.In the past, when I had simpatico speakers, I used Atma-Sphere M60's. Probably best amp I've ever owned. Much better than any Class A SS I have ever owned or heard.....and I have heard quite a few. FWIW.
Do you mind sharing which Class A SS amps you've owned? Do you still use the M-60's?
My current speakers are not a good match for OTL, so I no longer own AS. But I would not hesitate to do so again...with the right speakers.
Before he got going with the 'Anti Cables' thing, Paul Speltz made a name for himself with... http://www.zeroimpedance.com/These were specially made for OTL amplifiers to solve the problem of speaker incompatibility due to impedance issues. I used them in reverse with great success to solve another, but similar problem. They are somewhat expensive but very effective.
Sorry to keep asking...What is not a good match? What are the "right" speakers?
Hi Sunny, Curious what speakers you currently have?
Sunny Cable Technology H2W10.http://www.stereotimes.com/speak101007.shtml
Went from DIY FirstWatt F4 mono's and F5 to M60 MKIII.1's and have never looked back. The utter clarity and lack of any kind of grain is startling, even in comparison to the F5. See through quality without the edge.The smaller AS amps (S30, M60) are not for every speaker load but for my Geddes Abbeys, they work perfectly.
