0 Members and 1 Guest are viewing this topic. Read 227005 times.
Marius, they look good. I've been playing around with placement but it's a small room so not a lot of options. At the moment they are set up like this and I think it's working for me. They are 6'5" center of driver to center of driver:
Zu recommends 400+ hours of break-in time. Not sure if I can wait that long......... (that's almost 17 days straight)
To do a fair comparison....I'd ogo by what they say....
Is anyone else out there confused about the differences between the old Druid and the new Omen and Soul?
I'm confused with the Omen Def. vs. the Soul Superfly. They are priced within $100 of each other, so which is better and how would one choose between the two?
At the Black Friday prices, you've got the Soul Superly, Omen Def, and Essence all within $200 of each other. How would you choose?
I was told Omen was more geared towards solid state amps v/s Soul and Essense for tube amps.The comparision chart is also help: http://www.zuaudio.com/pdfs/comparisonchartlsweb.pdf
mariusz, not sure which decware amps you have, but if they are anything like mine were, (also 5wpc), i'd recommend getting something else to try w/the zu's. my decware amps really did not like any speakers higher than 8 ohms, and they preferred 4 ohms. they were completely lifeless driving 14 ohm 97db-efficient coincident wictory's, which are an extremely easy speaker to drive... i had (and still have) several other 4-8wpc tube amps that were heavenly w/the coincidents...ymmv,doug s.
.....or I could get a receiver (I think I still have Yamaha 3090 somewhere), which according to chart, brings excellent results across the board.
