0 Members and 1 Guest are viewing this topic. Read 9325 times.
I bought this one a few months ago:http://www.cryo-parts.com/pop_pulse_1796_dac.htmlThe price was right at $260, and so far I have no complaints about its performance. Of course, you might be able to find a better DAC within your budget ceiling.
Hi,I bought a few Zhaolu D3s for friends and family a while back. They enjoy them. If I was in your shoe though, I would seriously consider stretching the budget and get the Eastern Electric Minimax DAC @ $750 with the Saber 32 ES9018 DAC chip that has gotten crazy rave reviews right now. Switchable between tube and SS, volume control, a variety of inputs. Check it out.Kenobi
I decided to try the least expensive solution I could find. I just popped for a PopPulse SuperPro USB DAC 707 from Cryo-Parts. It takes up to 24/192 input via S/PDIF utilizing the same Cirrus Logic CS4398 DAC chip that is on the E-MU 1212M PCIe card I have in my PC. I bought a 1 ft. Belden 1694A coaxial digital audio cable from Blue Jeans Cable to run between the Squeezebox and DAC. I'll disable the volume control and FLAC file processing in Squeezecenter and pass 24/96, 24/176.4 and 24/192 straight through to the DAC. Once everything is in place I'll post my impressions.Martin
Interested to hear your impressions of the DAC. For the other SB units any file above 24/48 or above is downsampled in SOX software (built into all recent versions of SB Server) to 24/48 and passed along to the digital out of the SB unit in that form. Even the Touch and Transporter will get an SBS downsampled version of any file above 24/96 (e.g.,176, 192) to 24/96.
Well that sucks... for some reason I thought I had read somewhere that you could get Squeezebox server to pass up to 24/192. Martin
yes, you will need something like the HiFace usb>spdif out if you want 192 to your DAC. The descriiptions of SB stuff is a little confusing to the uninitiated. Yes, they will play 24/192, but not at native res. The devil is in the details. I have doubts SB will ever go to native 24/192. Little demand for it, and they are clearly repositioning the line toward mid-fi and low end audiophile market (Touch), not the true hi-end. Transporter is no longer being made.
Let's go bowling...Which EMU card do have btw? 1212? You've got the digital i/o so you can keep it as a transport no doubt to an external DAC (but quite a few are happy running balanced out of those AKM-based EMU). Solid drivers in my experience and Patchmix is really flexible. I still feel there is no substitute for having a PC front end gui like J. River, for organizational and usability reasons when compared to SB, but cost is an issue there. I run from my office/master server an ethernet cable (problems with with Intel 5300 [300MBps] drivers for wifi right now). You might also look into JRMC's new Event mode WASAPI; solved lots of problems for external DAC users over the basic WASAPI mode used by a lot of players.
I've been doing PC based audio exclusively (at least in the digital realm) for more than five years and the amount of hi-rez that I own is a very small proportion of the music I own and listen to. I have 2 Squeezebox Touch(es) w/ Bolder Cables analog mods and the quality of sound is ridiculously good for a total investment at the music listening spots way less than the OP's $500-600. The Touch plays 24/92 natively as well as Red Book. The SqueezeBox software has proven reliable and mostly foolproof over a long period. There is an active online community for help. The noisy parts are distant from the playback environment and once the commitment was made and the ethernet cables were run, connectivity is absolutely sturdy. Having this format of digital playback has absolutely changed my listening habits for the better.
I have the 1212M PCIe card. I run my Rokits off the balamced outputs and they sound darned good. I just installed foo_out_wasapi yesterday and got it working sending bit perfect streams to my soundcard. Amazing difference between it and the standard I/O. Listened to some of my 24/96 DVD-A rips some 24/96 and 24/176.4 material I downloaded from HD Tracks and other places. Very nice! I guess I could run 50' balanced cables out to my stereo. (Heck, they're only $30.38 a pair from Monoprice.)Martin
I have the 1212M PCIe card. I run my Rokits off the balamced outputs and they sound darned good. Martin
