How do you think these would work in a OB line array??? (PE close out)
0 Members and 1 Guest are viewing this topic. Read 1736 times.
djn
I was just borrowsing and saw these.  If I buy 10 or more, they are only $2.90.  The specs look pretty good, but then again, I don't know what I am doing.  What do you think?
Maybe with some ribbons or horns tweets.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-011
From PE
Well-engineered neodymium woofer for surrounds, mini monitors, or a component in compact multi-way systems. Magnetically shielded. Buyout, limited quantities. Specifications: *Power handling: 10 watts RMS/20 watts max *VCdia: 3/4" *Le: 1.12 mH *Impedance: 8 ohms *Re: 5.29 ohms *Frequency response: 60-4,000 Hz *Fs: 86 Hz *SPL: 85 dB 1W/1m *Vas: 0.14 cu. ft. *Qms: 5.15 *Qes: 1.19 *Qts: 0.97 *Xmax: 3 mm *Dimensions: A: 6", B: 5", C: 3-5/8" (including grill).
Stamped steel chassis with durable metal grill
Blue poly cone with rubber edge
4-layer copper voice coil on aluminum former
Neodymium magnet and extended pole piece
Designed for compact sealed box designs
