Jasmine audio phono lp 2.0se
0 Members and 1 Guest are viewing this topic. Read 2216 times.
Gopher
« on: 21 Sep 2010, 05:02 pm »
This phono pre has piqued my curiosity, but there seems to be so little info on it available...
I have a Ray Sammuels Nighthawk battery operated phono pre which is a pretty darn good performer. It took me some cartridge and cable juggling and a whole lot of tweaking around, but I managed to achieve a very musical synergy with it with one of the amps (a modified Dynaco ST-70) in my system. As good as I can get it to sound with the el34 amp, however, I've been striking out by comparison with the battery operated phono pre and a solid state amplifier in the loop (both Firstwatt F1 & F1J) with all else equal.
The Jasmine is pretty much at the same price point and I'm wondering whether anyone can offer any feedback on it. Someone who has steered me very right in the past with speakers and amplification dubbed it a giant killer and claims it killed a Manley Steelhead in his own rig--yet there is little info on it out there...
The things I really like about the NH are its transparency, dynamics, dead quiet (so long as placed away from noisy electronics) and versatility. What I wouldn't mind improving on are harmonic density and centering the balance a bit which might be tipped northward just a tad.
FWIW I'm using a Well Tempered Reference and Zu 103 cart (after much juggling the low compliance high mass Zu is doing me well in this position--I also have a 103D in a box).
Can anyone offer insight?
bacobits1
Re: Jasmine audio phono lp 2.0se
« Reply #1 on: 21 Sep 2010, 05:12 pm »
Fred, have you tried changing the tubes in the EE Mini Max pre?
You are using the Pre with both amps correct?
I have to check what I was running for tubes when I had it. I know it was a NOS Tungsol 6X4 but I forgot what else I was running.
That Jasmine was reviewed here>>
http://www.dagogo.com/View-Article.asp?hArticle=308
Also again with mods>>
http://www.dagogo.com/View-Article.asp?hArticle=28
Not that great here>>Beat by a Monolithic pre
http://www.positive-feedback.com/Issue24/jasminelp2.htm
D
Gopher
« Reply #2 on: 21 Sep 2010, 06:01 pm »
Den,
Yeah I shifted around tubes.  My synergy between my system with the Dynaco ST-70 is great with the NH in the mix.  My synergy with the Firstwatt has always been good for digital and not quite there for analog with the NH in the mix.
I came across those reviews before but I appreciate you posting them.  I was hoping for user feedback and may have to go back and pick the guys brain who mentioned it in the first place as he has 2 of the same cartridges as me and similar speakers and sonic priorities.
