0 Members and 1 Guest are viewing this topic. Read 4547 times.
am i correct that the output watts is solely based on the power supply (i.e. bigger supply = more watts?).
Ratso,I hope I don't step on any toes by making this post but... How do you feel about noise ( like hums and hiss ) coming from your speakers? Because unless the power you have coming into your home is squeaky clean, that's exactly what you'll run into with the JT Dynamic power supply. It's unregulated, which means all the noise running through your power lines will go through the amp and directly to your speakers. Now, if you have inefficient speakers / are sitting far away from them / don't give an earthly crap about noise - then its no biggy. If however, you think such a thing would bother you, I'd highly encourage you to take the battery route.
Just to give you and idea on color, Mesa(Yellow)/Columns/Cherry top
