0 Members and 1 Guest are viewing this topic. Read 11941 times.
I was messing around with my speaker cables and jumpers and hooked the speakers cables to the treble and then ran the jumpers down to the bass/mids. I was amazed, the sound was appreciable better, and the kicker was that the bass was better that way . Has anyone else experienced this? Can I potentially damage my speakers?
I'm not sure I'm following this. The only change you made was to hook the main feed from the amp to the upper terminals rather than to the lower? Everything else was the same? There were still jumpers of some kind between the terminals? If so, then I think what you heard is a physical impossibility. But maybe I'm not understanding the experiment correctly.
All, thanks for the responses.The "better" set of ears, the wife, noticed the changes, as did friends that came over for a listening session. I didn't post before going through the checks myself. There is a difference in bass power and over all clarity. I can check if the direction of the jumpers makes a difference, they are spades and the cables are bananas. I will pull and pop, and try it without re-orienting the jumpers. A very intriguing, "good" problem.
Coke, No nofication of changes to anyone. The wife came in during a listen and asked what I changed. We keep the volume pretty much the same all of the time, so there was no volume increase to attribute the change to. So no one else has experienced this?
