Luxman turntables
0 Members and 1 Guest are viewing this topic. Read 5748 times.
bogiedr
Luxman turntables
« on: 15 Sep 2010, 01:30 am »
Greetings!
I own a 198something Lux PX 100 quartz drive table. I am original owner and I know it was Lux's entry level model then. Still sounds incredible and does not seem to age at all! It is currently mated with a Clear Audio Aurum cartdridge. Does anyone have any experience with this table? I have thought about replacing it too may times but do not seem to find anything under $1,500 that feels to be the same quality build! I actually feel like upping the antie to a Lyra Delos or ClearAudio Maestro cartdrige just to see what it can do! Any input from the experts here? Thanks!
neobop
  • BIRD LIVES
Re: Luxman turntables
« Reply #1 on: 20 Sep 2010, 11:46 am »
Hi,
PX-100? Is it a linear tracker that looks something like this -
http://www.vinylengine.com/library/luxman/px-101.shtml
There's a very cool looking one on Audiogon, a 441. It has a magnetic floating suspension (platter) and space for 2 arms. It's under $1K.
Maybe with a little more info about your table we could better advise about a cartridge. You're already using a Clearaudio, so the Maestro should be OK. Not sure about the Lyra though. You might want to consider upgrading the deck instead.
bogiedr
« Reply #2 on: 21 Sep 2010, 01:25 am »
My PX 100 is a quartz, (direct drive) table. I believe it was made for Luxman by Micro Seiki. I do know it was the entry level model for Luxman at that time. It is a fully automatic, semi auto or fully manual, your choice! There is not a lot of information to be found online. I have tried researching it and there is not a whole lot. All I can say is I like it a lot, it is reliable and sounds excellent. A better cartdridge than a re tipped ClearAudio Aurum should sound incredible. I have thought about a C.A. Beta S which can be had reasonably priced on Audiogon or even a Virtuoso. I am afraid I do not know much about other brands such as Sumiko, Grado or others in order to make a sound decision. If you good folks can at least give me impressions on your favorite cartridge brands it will give me reserach material!! Thanks and hit them straight!!!!
neobop
  • BIRD LIVES
« Reply #3 on: 22 Sep 2010, 04:01 am »
Retipped Clearaudio? Depending on how it's retipped you might not do any better moving up the line. I've been playing around with modifying an AT-95. The Clearaudio carts take the same stylus as a 95 with the plastic wings removed. AT makes the Clearaudio carts for them. I picked up a Virtuoso with a busted cantilever and put in an aftermarket shibata stylus made for the 95.
After doing a little research it seems that all the Clearaudio generators are the same throughout their MM line. So, if you have an exotic cantilever and a micro diamond, I think it should be roughly equivalent to a Maestro even though yours is entry level cart.
I found no information on your table. The 101 didn't look to good, but I assume yours is an entirely different animal.
neo
bogiedr
« Reply #4 on: 24 Sep 2010, 11:59 pm »
Neobop, it was rittiped by ClearAudio. It sounds very good, just not sure if more $ means better sound! Based on your response I should let it be.  :duh:
neobop
  • BIRD LIVES
« Reply #5 on: 25 Sep 2010, 02:38 pm »
If it sounds good then just enjoy. After another 1000 hrs or so, I'd send it to Soundsmith. For $350 it could get a ruby/micro LC. I really think all the CA generators are the same. They all have 420mH and 660 ohms. You could buy a cheap conical replacement for the AT-95 ($25) for the plug that holds the cantilever and a real good AT stylus to transplant. It's a little hairy though. If you're interested, check out the thread in carts on VE. Called AT-95E, the last 3 or 4 pages are about potting and stylus transplanting mostly.
In the mean time, maybe some other part of your system could use upgrading? Maybe a RCM or a bunch of records is always nice. Oh, I did find a pic of your TT. It looks a whole lot better than the 101.  :wink:
neo
bogiedr
« Reply #6 on: 2 Oct 2010, 01:21 am »
I think you are correct, If it sounds good, shut up and enjoy it!!  :duh: The tweeks I should be working on are things like better cables for sources, acoustic treatments, that type of thing. The current set up sounds incredible, so why mess with more equipment "upgrades"?  :green: Just for that, I will place Yamashta, Windwood, Shrive's "Go" on the VPI cleaner, pop it on the table, crank the volume and enjoy!!!!  :thumb:
Thanks for the input! Great advise.
