Bottlehead Foreplay/Turntable/Computer system help needed
0 Members and 1 Guest are viewing this topic. Read 1156 times.
starkiller
Kinda involved, am getting a BH Foreplay II, 3 inputs-1 ouput. I would like to use it in my computer system that has a TT. So was going to get a phono pre to use, but, i also have a tuner/cd player and the computer as inputs. How do i get another input so i can still run my computer's sound through the system?
The answer is probably easy but i don't know it :)
jimbop
Re: Bottlehead Foreplay/Turntable/Computer system help needed
« Reply #1 on: 15 Sep 2010, 03:10 am »
Contact the folks at Bottlehead, or post your questions on the Bottlehead Forum:
http://www.bottlehead.com/smf/index.php
JD
JohnR
« Reply #2 on: 15 Sep 2010, 04:49 pm »
You'd need to replace the switch with a four-position one, and mount the additional jacks on the plate.
Might be better to start with something that meets your current needs.
