USB to SPDIF converters with RWA products
0 Members and 1 Guest are viewing this topic. Read 4112 times.
kitten
« on: 14 Sep 2010, 02:51 am »
Hi folks, wondering whether anyone has had any experience with USB to SPDIF converters with RWA gear?
Many of these have come onto the market recently. Interested in both asynchronous (e.g. Ar-t Legato) or adaptive (e.g. Sonicweld Diverter) designs - don't really want (and do not think this is the place) to get into a debate about which approach is best or whether these converters are even a good idea generally, just your experiences with Vinnie's products please. Are the Isabella and her siblings immune to these  -- or do they actually result in a worthwhile sonic improvement? FWIW, I don't hear a difference between USB directly into my Isabella and CD transport > SPDIF > Isabella so it's not a case of raising PC playback to be on a par with CD, it already is for me. So, can use of a converter with Vinnie's gear allow PC playback to surpass a CD transport is I guess what I'm wondering....
adamaley
Re: USB to SPDIF converters with RWA products
« Reply #1 on: 16 Sep 2010, 11:57 pm »
You might get better response at Computer Audiophile. I read about the diverter over there, and they have a fair share of Red Wine Audio users there. Never heard of the Ar-t Legato. Good luck.
wilsynet
« Reply #2 on: 17 Sep 2010, 06:51 am »
I used the Empirical Audio OffRamp 3 w/superclock4 and the BPT battery power supply and to my ears it certainly kicked it up a level versus the standard USB input of the Isabella/Isabellina.  A meaningful and significant level for me.
On the other hand, it is either worse or no better with the stock M2Tech.
Your mileage may vary, but I think some of the more expensive USB to SPDIF converters are very good indeed.
JKeny's mods for the M2Tech have intrigued me for some time.
kitten
« Reply #3 on: 21 Sep 2010, 01:47 pm »
Thanks adamaley, I will check this out.
Hi Wilson, thanks for the feedback. Based on your experience I think I'll give one or two of these a try and listen / decide for myself.
What type of cable did you use between the OffRamp and Isabella?
Greg
wilsynet
« Reply #4 on: 21 Sep 2010, 02:19 pm »
A very ordinary coaxial cable from Blue Jeans Cable.
Vinnie R.
    • http://www.vinnierossi.com
« Reply #5 on: 21 Sep 2010, 06:37 pm »
The Blue Jeans Beldin 1694A "Brilliance" digital cable (with 75-ohm BNC plugs) is very good and priced extremely well!  8)
http://www.bluejeanscable.com/store/digital-audio/index.htm
Best regards,
Vinnie
kitten
« Reply #6 on: 22 Sep 2010, 03:59 am »
Done! Many thanks
kaka
« Reply #7 on: 22 Sep 2010, 10:35 am »
The advantage is that you can play material at 88, 96, 176 or 192 via a suitable USB converter, while the Isabella tops out at 48 via the USB input.
I have used an Empirical Audio Offramp3 into an Isabella, but I prefer attaching a volume controlled dac to my poweramps without using a preamp.
Socrates7
  • Find me at http://parttimeaudiophile.com/
    • Part-Time Audiophile
« Reply #8 on: 21 Oct 2010, 05:38 pm »
Check out the Legato at: http://www.analogresearch-technology.net/LEGATO.html. Best I've found for Redbook audio. Great stuff.
