Help, how to reset standby mode of Marantz SR8001 receiver
0 Members and 1 Guest are viewing this topic. Read 2846 times.
nhotumlum
I bought Marantz SR8001 over a year, but I had send to Marantz authorized repair center third times already. The problem is the standby mode keep flashing. ( After I received my Marantz receiver back from the repair center, play less than an hour, it automatic switch to standby mode )My speakers are Monitor Audio GS20, and Adcom GFA-555 amp which connected to pre-out Marantz receiver. Can any one show me how to fully reset the standby mode. Thanks
writeface
Re: Help, how to reset standby mode of Marantz SR8001 receiver
« Reply #1 on: 13 Sep 2010, 06:53 pm »
I was told by Marantz tech support that you can't reset it and it must be taken to the service center.
My SR8002 went to the same state after nearly 2 years of performing well. It is now at the repair shop @mt.view. It has been 2 weeks and it is not back yet. If it does this again I am going to ditch it and may go receiver-less(!).
Hope you find a solution.. Did you complain to Marantz directly? Why won't they replace the whole unit if it is still under warranty?
nhotumlum
« Reply #2 on: 13 Sep 2010, 08:31 pm »
I complained and they not going to replace the whole unit, yes it is still under warranty. They asking me to send them the unit, when it fixed, they will send it back. Which I already did 3 times
