Anyone use tube cd player with Bryston gear?
0 Members and 1 Guest are viewing this topic. Read 2722 times.
Tony1
« on: 13 Sep 2010, 05:21 pm »
Curious to get some opinions on this.  Don't know if it's a bad idea to mix tube gear with solid state.  I have SP1.7 and 9bSST. I've heard that tube cd players bring warmth but no sure if you need all tube pre and amp for it to sound good and if it's a bad idea to mix.
Tony
95Dyna
Re: Anyone use tube cd player with Bryston gear?
« Reply #1 on: 14 Sep 2010, 02:53 pm »
It's not a bad idea to mix.  It depends on your other components and whether you need more warmth or brightness.  There is an excellent player out there that has both tube and ss output stages, plays CD/SACD/HDCD and has digital inputs, the Cary CD 303T SACD Professional Version.
http://www.caryaudio.com/products/classic/CD303TSACDPro.html
Napalm
« Reply #2 on: 14 Sep 2010, 04:18 pm »
Anyone using a discrete tubes DAC?
I've heard it's the real thing.
Nap.  :thumb:
vegasdave
« Reply #3 on: 14 Sep 2010, 06:24 pm »
haha. good one!
Stu Pitt
« Reply #4 on: 15 Sep 2010, 03:29 pm »
I thought that was Laudrew's DAC!
Uptown Audio
    • http://www.uptownaudio.com
« Reply #5 on: 15 Sep 2010, 07:46 pm »
Tony
I prefer a true tube preamp to a tube buffered or tube output stage on a CD player. The best sounding CD players that I have heard are not tubed. The DAC in the SP1 is actually quite nice. Perhaps feeding it a bit better signal would help. It's not the last word in resolution but has a well balanced sound.
A true tube preamp, bypassing the SP1 for stereo use, would yield an entirely different experience. All tubed devices will add noise but I find that a tubed linestage is a good addition. They provide a more three dimensional sound stage than SS components. They can range from syrupy sweet and warm to brighter and overly gainy or punchy sounding. Obviously, the best designs will be somewhere in between.
By contrast, every tubed CD player I have heard just seemed to compress the signal and add a muffled coloration to the sound. Softening the sound, yes. Taking the edge off of a harsh digital source, yes. But this is at the cost of a dumbing down of the original. I prefer to have a better quality source and a great quality preamp. The preamp can be SS or tubed but the CD player should almost always be SS in an advanced hi-fi system.
-Bill
Robert D
« Reply #6 on: 16 Sep 2010, 03:41 pm »
http://www.soundfountain.com/amb/cd25years.html
A Must Read  and learn :thumb:
Robert
Napalm
« Reply #7 on: 16 Sep 2010, 07:48 pm »
I guess you rejoiced at stuff like this:
"Although the resolution of the signal and the depth of the sound are very low in quality, relative to the analog tape and LP, this disc is to be the modern substitute for the vinyl long playing stereo gramophone record."
However do not forget that these days the most damage is done in the studios, especially during mastering. You could give them 128bits/2GHz LPCM and they would still produce the same cr*p.
Nap.
Tony1
« Reply #8 on: 17 Sep 2010, 12:33 am »
Thanks everyone, great info.
rob80b
« Reply #9 on: 17 Sep 2010, 04:38 pm »
Robert
No tubes, but a nice refresher course.
Robert
