SOLD: Parasound P/PH-100 Phono Preamp
0 Members and 1 Guest are viewing this topic. Read 2363 times.
gitarretyp
« on: 12 Sep 2010, 07:09 pm »
I bought this MM/MC phono pre new a number of years ago, but it's mostly resided in its original as I've never gotten very seriously into vinyl. As such, it's in essentially like new condition and includes the original box and manual.
The features and specs are:
Works with all line drive preamplifiers
RIAA curve accurate to 0.25 dB
Ultra low distortion
Internally selectable adjustment for moving coil or moving magnet
Analog Devices operational amps
Audiophile grade resistors and capacitors
Computer grade glass epoxy circuit board
Gold-plated RCA jacks
9 1/2" width front panel
Removable IEC AC cord
1 rack space height front panel
Two unit fastening hardware available for side-by-side rack mounting
Specifications:
Input Sensitivity: moving magnet: 2 mV; moving coil: .5 mV
Input Impedance: 47k ohms
Input Overload: 220 mV, I kHz mm
RIAA Accuracy: 0.25 dB, 20 Hz - 20 kHz
S/N Ratio: 72 dB, ref 5 mV input
Dimensions: w 9 1/2" x h 1 3/4" x d 7", h 2 3/8" with feet
Net Weight: 3 lb.
Asking $100 plus shipping.
« Last Edit: 25 Oct 2010, 04:21 am by gitarretyp »
gitarretyp
Re: FS: Parasound P/PH-100 Phono Preamp
« Reply #1 on: 26 Sep 2010, 02:45 pm »
Bump.
