Boutique parts list for Bugle?
0 Members and 1 Guest are viewing this topic. Read 1501 times.
bigdirty
« on: 12 Sep 2010, 06:49 pm »
Im interested in putting together a bugle for a beginners project. Im curious, would using boutique caps and resistors and whatnot make a significant increase to sound quality?
Can anyone help me with where i would make some boutique parts substitutions from the parts list?
thanks for you time.
analog97
Re: Boutique parts list for Bugle?
« Reply #1 on: 13 Sep 2010, 01:10 pm »
Big,
You say you are a beginner.  My recommendation is to stick to stock parts at first.  Get some experience, then go for the exotic parts.   Exotic parts tend to be bigger, sometimes just too big, causing placement problems that a more experienced person easily deals with.  I built a stock Bugle and it is very nice.  Good luck if you decide to go the exotic route and others can help.  Also do a search and you will find many experiences about Bugle upgrades.
