0 Members and 1 Guest are viewing this topic. Read 8919 times.
The IP address I posted will give you the same screen on your mobile device effectively that you see on your server in the other room.Bryan
If you want to give JRMC another try you will want to check out the XPTunes interface. It's much better than the built in web interface and is similar to iPeng.
What made you fall in love with this new USB DAC and is it actually better than your Modwright Transporter? Or is it just something new to play with?
Squeezeplay worked fairly well, except that it doesn't seem to handle hi-rez (96k) files at all.It also doesn't allow for plugins, meaning I can't use the EQ plugin that I unfortunately rely on.I will try JRiver with XPTunes and see how that works.
Then there's the requirement to have a computer in your listening room. The limitations to USB cable length. And the worst part of it: Using a consumer grade computer as a digital audio transport. Read some other forums to see the lengths many people have gone to in order to get their "music servers" to sound passable. The trifling little hardware tweaks and software changes that come out almost daily (and are argued ad infinitum) that make large differences in the sound quality. It's never ending and it makes absolutely no sense unless you embrace driving yourself nuts worrying about and fiddling with such things.
I use an iPad for a remote, so there are ways of controlling all these players, but the feature set varies between them.
Have you looked into running remote desktop software on the computer and the iPad? Then connect to the computer and remotely run whichever native audio application that you prefer. You should have sufficient screen resolution on the iPad to do this.
