Static On Clarinet Volume Control
0 Members and 1 Guest are viewing this topic. Read 1976 times.
david62
« on: 9 Sep 2010, 12:25 pm »
My Clrinet gives a small amout of static when ever the stock volume pot.is moved.It is almost a year old.Should I use Deoxit on it?
WGH
Re: Static On Clarinet Volume Control
« Reply #1 on: 9 Sep 2010, 02:28 pm »
Bill Thomas posted excellent cleaning directions for dirty pots:
http://www.audiocircle.com/index.php?topic=85179.msg829349#msg829349
Wayne
david62
« Reply #2 on: 9 Sep 2010, 06:25 pm »
Is it normal for a pot with low hours,less than a yr.old to become dirty?
christos
« Reply #3 on: 10 Sep 2010, 11:38 am »
Normal, no. Possible, yes, especially if you use the pot specified in the instructions. Those pots are pretty cheap. Also the less you use it the worse it is, since you don't take advantage of the normal wiping action. If you live in a dry climate it seems to make things worse.
I am sure you can easily clean it, as others have pointed out, but this seems like an opportunity to get that nifty stepped attenuator you were thinking about!  :)
david62
« Reply #4 on: 11 Sep 2010, 09:40 pm »
The problem with putting a stepped attenuator in is that I have a nice drilled chassis front panel that I don't want to replace.Could I fit one in and not have to replace the front panel?
christos
« Reply #5 on: 12 Sep 2010, 05:17 am »
One idea is to remove the existing pot, plug the hole, and install the attenuator somewhere else, either above or below the horizontal line where the existing pot is situated. You have to decide if it can be made to look right to you. Perhaps a large knob might make the offset location look intentional.
However, I would just clean the existing pot first. You may find that this is all is needed.
david62
« Reply #6 on: 13 Sep 2010, 03:18 pm »
I just had laser etching of the front panel with the print downloaded from this site that has the Hagerman logo and all.It looks wondeful,so I will be cleaning the pot.It is not that bad anyway.
David
